1989 Nissan Sentra Engine won't turn over/fire up
50,000 MILES • 4 CYL • 2WD • AUTOMATIC
RETAMAY
This car broke down a year ago, got all new parts put in just recently (engine, transmission, transaxles, starter, alternator, power steering unit, ac unit, hoses, belts, fluids, new battery) and now that the mechanic is done putting the car together with all the new parts, he can't seem to get it to run. What all else could be wrong with the car? It has always started up just fine before it broke down, but now with new parts, it won't fire up.
Aug 27, 2010 at 9:37 AM
  • 75,988 POSTS
What is it doing? -cranking over and will not start or just won't crank at all/nothing when you turn key to cranking position?
Aug 27, 2010 at 9:46 AM
RETAMAY
It cranks, but doesn't start.
Aug 27, 2010 at 1:48 PM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem,If you can hear the fuel pump come On- check the fuel pressure with a fuel pressure tester designed for your fuel system to rule out the fuel filter/fuel pick-up strainer/fuel pump/pressure regulator and also listen to the injector/s are they pulsing or hook up a noid light and see if it flashing, If you don't hear the fuel pump, check the fuel pump fuse and fuel pump relay-Depends on what type ignition system is yours,No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, camshaft and crankshaft position sensors and computer Note: If it doesn't apply to your vehicle disregard it meaning if it doesn't come with one ignore it and continue testing
Aug 27, 2010 at 2:50 PM
