1988 Nissan Sentra 4 cyl Two Wheel Drive Manual 87k miles
I have a Nissan Sentra '88, no start, no fuel pulse, no spark, no LED's at ECU, no fuel pump coming on. Replaced timing belt, dist. With known good one, ECU with known good one, coil, checked grounds, replaced neg. Bat. Cable, checked fuse box connections and relays. Still have same problem happening. Have replaced fusible links at battery. No power to distributor. Still no change. Need help! Thanks a bunch in advance.
SPONSORED LINKS
Thursday, December 27th, 2007 AT 6:21 PM
