1996 Nissan Pathfinder No Start
MAHMUD_17
1996 pathfinder se with about 150,000 miles will not start by turning the key, its a manual so it will jump start fine, i had the stsrter checked and its ok, i turn the key everything clicks like normal but no start?
Jun 7, 2006 at 4:19 AM
TREKINOUS
  • 28 POSTS
Try checking the starter wire. I had the same problem on my 1994 Pathfinder and after removing the starter wire and cleaning the ends off it seemed to work fine.
Mar 4, 2007 at 9:32 AM
  • 75,988 POSTS
[quote:3755f71faf="mahmud_17"]1996 pathfinder se with about 150,000 miles will not start by turning the key, its a manual so it will jump start fine, i had the stsrter checked and its ok, i turn the key everything clicks like normal but no start?[/quote:3755f71faf]
Have you check the clutch switch at the pedal or the starter relay
Mar 4, 2007 at 1:37 PM
Suggested Repair
Check the clutch safety switch at the pedal and the starter relay. Also inspect and clean the starter wire connections.
Conversation Summary
The owner of a 1996 Nissan Pathfinder SE manual says it will not crank with the key, although it jump-starts and the starter tested okay. Turning the key produces normal clicks but no start. A user suggested cleaning the starter wire ends, and the expert recommended checking the clutch switch at the pedal and the starter relay.
