2006 Nissan Pathfinder Factory Radio one CD only Player
2006 NISSAN PATHFINDER
107,000 MILES • 6 CYL • 2WD • AUTOMATIC
AGUSTINCORREA
  • 6 POSTS
HI Again,
I have a problem with my Car Cd Player. For some reason stops playing for 3-5 seconds and then continues on most CD's Burned or Purchased, Even if you fast forward it stops and goes. Don't know id the lens is dirty and needs to be reopened to be cleaned or is something else. The radio works perfect and there might be times that the CD will work properly. I even bought a Cd Cleaner at radio shack and didn't fix the problem.
Let me know if the Cd can be fixed or a new Radio is needed?
Thanks,
Augie
Jan 25, 2010 at 7:44 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I am leaning toward a faulty Lazar reader, often as they get older the Lazar starts to break down, normally you get this more with burnt CD's first as the quality is a Little poorer, cleaning wont restore the unit as you have found, often a new Lazar is near the price of a new CD player, so i would just get the opinion of a radio tech, but be prepared to go get a new player.
Mark (mhpautos
Jan 25, 2010 at 12:19 PM
