2001 Nissan Pathfinder Leaks water on the passenger floor
2001 NISSAN PATHFINDER
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
CWOMAN
The airconditioner leaks water on the passenger side floor, gets worse when I make a left hand turn. What is the problem and can I fix it?
Jul 23, 2008 at 5:20 AM
90JEEPMAN
[quote:4c6c50e9c4="cwoman"]Air Conditioning problem
2001 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic 130000 miles
The airconditioner leaks water on the passenger side floor, gets worse when I make a left hand turn. What is the problem and can I fix it?[/quote:4c6c50e9c4]
there is a drane on the passenger side under the car it is stoped up take a air hose and blow it out. or take a long screwdriver and stick it in the tube and clean it out....
Jul 27, 2008 at 8:03 AM
