2001 Nissan Pathfinder V6 Two Wheel Drive Automatic 146743 miles
vehicle ran low on fuel, after fueling engine has poor acceleration, also would only run aprox 35mph. Started checking fuel system changed fuel filter since it had been awhile. And then engine wouln't accelerate when in park it sputters and cuts out now. Checked fuel pressure it had 2psi before the fuel rail & when reving fuel psi dropped to 1psi and engine dies. So I changed fuel pump and engine is still doing same thing. Also noticed on throttle body there is a sensor or some kind of relay that is clicking or unspooling when key is turned off could that be my problem? Any suggestions would be appreciated greatly
SPONSORED LINKS
Wednesday, December 5th, 2007 AT 7:32 PM
