Nissan Front Left Clunk Over Bumps
NISSAN
KITTIEMALIBU
  • 7 POSTS
please help... i have this awful clunking noise everytime i go over any kind of bump or uneven ground...it's coming from the front left end near the tire... i think it's the strut or maybe bushings....any advice... it's driving me crazy and it sounds like the whole front end under carage is about to fall off... but 2 different mechanics and myself can not find anything loose....
May 5, 2006 at 6:55 AM
LOSONE
  • 1,616 POSTS
It sounds like a strut or many a loose exhaust hanger rubbing when you hit a bump. Grab a cold tailpipe and shake it. It it moves a lot, maybe that's the problem if no a strut or shock. Good luck
May 5, 2006 at 10:30 AM
KITTIEMALIBU
  • 7 POSTS
Thanks so much... i am figuring it's a strut... i hear it only in the front end... but i will def. check the tail pipe.. cause i'm starting to hear noise back there as well.. thanks for the advice
May 6, 2006 at 2:23 AM
CBAILEYII
  • 26 POSTS
With the car parked, set the tires parallel and try shaking the car by the driver side tire pushing in and out on the top of the tire toward the engine compartment. If you notice any kind of play, you may have a bad ball joint.
May 7, 2006 at 5:18 PM
KITTIEMALIBU
  • 7 POSTS
I have tried that with all my tires and i even had new tires put on and re balanced and 2 alignments done... and nothing is loose as far as that goes... not sure yet.. and i'm starting to get nervous as far as driving it cause i'm starting a new job with a drive tagged onto it... thanks so much for the advice!!!! i will try it again...
May 8, 2006 at 12:12 AM
LOSONE
  • 1,616 POSTS
When all else fails one has to accept the advice of a mechanic. Have it looked at by a trusted front end mechanic. Say away from Muffler shops. Good luck
May 8, 2006 at 1:32 AM
KITTIEMALIBU
  • 7 POSTS
indeed...that's funny cause i just called a friend to refer me to one... cause at this point i think i'm going to have to suck it up and go to one....
thanks bunches again!
May 8, 2006 at 2:03 AM
Suggested Repair
Check the front-left strut or shock and shake the cold tailpipe for a loose exhaust hanger. Also check for ball-joint play. If nothing is loose, have a trusted front-end mechanic inspect it rather than a muffler shop.
Conversation Summary
A Nissan owner reported a clunk from the front left over bumps, with nothing found loose after tire, balance, and alignment work. Replies suggested checking the strut or shock, exhaust hanger, and ball joint, then taking the car to a trusted front-end specialist.
