300ZX Cold or Wet Squeak
1930 ALL OTHER MAKES ALL OTHER MODELS
A3Z0N0ZX
when i turn on my engine, there would be a squeaking noise and it squeaks when i drive also. after i gain speed or the engine is warm then the noise goes away. this only happens when the engine is cold or if its raining. could it be the belts? a mechanic told me it was because my power steering belt was dry. im thinking about replacing my alternator drive belt, power steering belt and the a/c belt. someone help. thanks!
Jan 7, 2006 at 4:52 PM
2CARPRO JACK
  • 11,533 POSTS
I would replace all the belts and inspect the tensioner
Feb 8, 2006 at 9:46 AM
CHEVY350GUY
  • 109 POSTS
rust in the groves on the pullies can cause this
Feb 8, 2006 at 11:37 AM
Suggested Repair
Replace all the belts and inspect the tensioner. Also check the pulleys for rust in the grooves, which can cause squeaking.
Conversation Summary
The owner reported a squeaking noise on a 300ZX when the engine is cold or in rain, which stops once the engine warms up or speed increases. A mechanic had suggested a dry power steering belt, and the owner was considering replacing the alternator, power steering, and A/C belts. Experts advised replacing all the belts and inspecting the tensioner, and noted that rust in the pulley grooves can cause this noise.
