A/C clutch
NISSAN
LINDAU522
my 1990 Stanza with 145000 miles
the A/c clutch will not engage neither will the radiator fans come on when I hit the a/c switch
the fuse is ok and i changed the relay still nothing
HELP
Nov 27, 2007 at 9:19 AM
  • 31,937 POSTS
Hi there,
The A/C system ha s a low pressure cut out switch, which will not allow the clutch to come on if the internal system pressure is to low. You may have a leak and lost you refrigerant gas. They will have to do a vacuum down and see if it holds vacuum before re filling.
Mark (mhpautos)
Nov 27, 2007 at 11:15 AM
