What do you suggest....
1986 Nissan Stanza Won't Crank
What do you suggest....[/quote:416cc63518]
Remove all the sparkplugs spray some WD40 on ea. port-try and crank engine over without the plugs.
Cranking problems continue with a known good battery and connections clean/tight. Then its time to check the starter relay and starter. Also a voltage drop test on each cable pos. and neg.
Remember 1yr is a long time the engine is tight-similar to a hydrolock but less-
Good Luck
Suggested Repair
Remove the spark plugs, spray WD-40 into each port, and try cranking with the plugs out to free a tight engine after long storage. If it still only clicks with a known-good battery and clean, tight connections, test the starter relay and starter and perform a voltage-drop test on the positive and negative cables.
Conversation Summary
A 1986 Nissan Stanza with 175,000 miles sat for about a year and will not start. The owner replaced the fuel and battery and cleaned the spark plugs; it almost turns over, then clicks as if the battery is dying, although the lights stay bright. The expert advised removing the plugs, spraying WD-40 into the ports, and cranking without plugs because the engine may be tight. If cranking problems continue, check the starter relay and starter and do a voltage-drop test on both battery cables.
