It could be the alternator or a different problem so you will need to do a few check and test first to make sure.
First make sure the battery is good. Check with a volt meter and see if you have at least 12. volts at the battery with car off and no other accessaries are on.
Second do a load test on the battery. If you don't have a battery load tester you can improvise. Disable the ignition system by removing the coil wire to prevent the car from starting. With the volt meter connected to the battery have an assistant crank the engine (No more then 10 seconds) and watch the volt meter. (If there is one in the car you can used that one instead) The voltage should not drop below 9 volts. If it does then recharge or replace battery before doing any more testing..
If all test above where good then start the car and test the alternator. With the car running the voltage should range between 13.5 to 15.5 volts but never below 13.5 with all the accessaries on. If voltage is not in range replace the alternator. If all goes well in the above check the fuse box for a defective fuse. Hope this helps Backyardmechanic :)
Nov 30, 2006 at 1:53 AM
