1996 Nissan Maxima Late 2nd Shift
FARGOGUY53
I have a 1996 Nissan Maxima 3.0L w/auto transmission, 150,000 miles, which shifts into 2nd only when the engine has rev'd to 3500rpm. Any thoughts?
Chuck Trapp
May 27, 2007 at 5:14 AM
KAMO
  • 47 POSTS
I would check your speed sensor and change your tranny fluid. That may improve the problem. You car should normally shift closer to 3000 rpms, but the first place to check would be the speed sensor.
May 27, 2007 at 9:05 AM
  • 75,988 POSTS
[quote:32332d1ddd="Fargoguy53"]I have a 1996 Nissan Maxima 3.0L w/auto transmission, 150,000 miles, which shifts into 2nd only when the engine has rev'd to 3500rpm. Any thoughts?
Chuck Trapp[/quote:32332d1ddd]
Last transmission service?
Have the throtttle position and vehicle speed sensors check-before you get to the shift solenoids.
May 27, 2007 at 9:09 AM
Suggested Repair
Confirm when the transmission was last serviced, then have the throttle position sensor and vehicle speed sensor checked before considering the shift solenoids. A fluid change and speed-sensor check may also help if the 1-2 shift is delayed past about 3000 rpm.
Conversation Summary
The owner of a 1996 Nissan Maxima 3.0L automatic with 150,000 miles reports that it shifts into 2nd only after the engine reaches about 3500 rpm. One reply suggests checking the speed sensor and changing the transmission fluid, noting a normal shift closer to 3000 rpm. The expert asks about the last transmission service and recommends checking the throttle position and vehicle speed sensors before moving on to the shift solenoids.
