1991 Nissan Maxima No Forward Gears
TIM M.
I HAVE A 1991 NISSAN MAXIMA 4 DOOR WITH 167,000 MILES AND AN AUTOMATIC TRANSMISSION. MY TRANSMISSION WONT DO ANYTHING IN ANY FORWARD GEARS. THIS HAPPENED WHEN GOING HOME ONE DAY AND I SLOWED DOWN AND TURNED A CORNER AND IT JUST ACTED LIKE IT WAS IN NUETRAL. WHEN I PULLED OVER I PUT IT INTO REVERSE AND BACKED IT OFF THE STREET AND INTO A PARKING LOT AND REVERSE WORKS JUST FINE, BUT IT WILL NOT MOVE IN ANY FORWARD GEAR. THERE DIDNT SEEM TO BE ANY SLIPPING OR ANYTHING PRIOR TO THIS, ALTHOUGH ONCE BEFORE THIS WHILE I WAS PULLING INTO A PARKING SPACE IT ACTED THE SAME WAY.. I PUT IT INTO PARK AND SHIFTED INTO DRIVE AND IT WHENT INTO GEAR AS IF THERE WAS NOTHING WRONG WITH IT. DOES IT SOUND AS IF MY WHOLE TRANSMISSION IS SHOT OR COULD THERE BE SOMETHING ELSE CAUSING THIS?
Jul 12, 2007 at 9:10 AM
  • 75,988 POSTS
[quote:aaff50d78d="TIM M."]I HAVE A 1991 NISSAN MAXIMA 4 DOOR WITH 167,000 MILES AND AN AUTOMATIC TRANSMISSION. MY TRANSMISSION WONT DO ANYTHING IN ANY FORWARD GEARS. THIS HAPPENED WHEN GOING HOME ONE DAY AND I SLOWED DOWN AND TURNED A CORNER AND IT JUST ACTED LIKE IT WAS IN NUETRAL. WHEN I PULLED OVER I PUT IT INTO REVERSE AND BACKED IT OFF THE STREET AND INTO A PARKING LOT AND REVERSE WORKS JUST FINE, BUT IT WILL NOT MOVE IN ANY FORWARD GEAR. THERE DIDNT SEEM TO BE ANY SLIPPING OR ANYTHING PRIOR TO THIS, ALTHOUGH ONCE BEFORE THIS WHILE I WAS PULLING INTO A PARKING SPACE IT ACTED THE SAME WAY.. I PUT IT INTO PARK AND SHIFTED INTO DRIVE AND IT WHENT INTO GEAR AS IF THERE WAS NOTHING WRONG WITH IT. DOES IT SOUND AS IF MY WHOLE TRANSMISSION IS SHOT OR COULD THERE BE SOMETHING ELSE CAUSING THIS?[/quote:aaff50d78d]
Try checking the TPS and VSS sensors it has something to do with shift timing and locked-up
Jul 12, 2007 at 1:09 PM
Suggested Repair
Check the throttle position sensor (TPS) and vehicle speed sensor (VSS), which affect shift timing and torque-converter lockup, before concluding the transmission has failed.
Conversation Summary
The owner of a 1991 Nissan Maxima with 167,000 miles says the automatic transmission suddenly will not move in any forward gear, while reverse works normally. There was little prior slipping, and a similar episode once recovered after shifting to park and back to drive. The expert suggests checking the TPS and VSS sensors related to shift timing and lockup.
