Tire Always Going Flat
MARC L.
I recently had new tires (Very Good Qaulity Tires) put on my 2001 Nissan Maxima SE with V6 Engine (60,000 miles), but since, one tire in particular goes flat every couple of months. The tire store where I bought them indicates that the seal is not properly sealing because of rust on the rim and that I will need a new rim. I have never heard of this, usually hold my cars for over 10 years and never experienced something like this. Before I go spending money on a new rim, can someone advise if they have heard of this problem with Nissans or any car for that matter? Thank you.
Nov 30, 2007 at 3:17 AM
BLACKOP555
  • 10,386 POSTS
that is a common problem, but also fixable, you can easily wire brush it off with a wire brush. You may also have a bad valve stem or core. fill the tire up about 5 pounds to 10 pounds over and spray soapy water on it and look for the bubbles.
Nov 30, 2007 at 4:15 AM
