Where is the starter located?
Aug 21, 2007 at 2:41 AM
Locate the starter between the engine and transmission by following the positive battery cable. Disconnect the negative battery terminal first. Use 12 mm and 14 mm wrenches. To remove it, disconnect the starter wiring, remove the mounting bolts, and take out the starter; raise and support the vehicle if needed.
Owners of 1997, 1996, and 1990 Nissan Maximas asked where the starter is located and how to replace it. Experts said it sits between the engine and transmission and can be found by following the positive battery cable. They advised disconnecting the negative battery terminal first, then disconnecting the starter wiring and removing the mounting bolts.
