1998 Nissan Maxima Intermittent Failure to Start
STEVEPARSONSGA
  • 1998 NISSAN MAXIMA
My daughter's Maxima has an intermittent problem. So far we have replaced the battery, starter, and the sensor that interlocks the automatic transmission shift (to avoid starting in any postion except park). There seems to be no pattern to the problem which may go for a month or two without showing up. Two different mechanics have tried to debug the system but the car will not fail to start when they have it in for check out. The car's electrical system is
up and running (stereo, lights, etc) when the failure occurs. Most of the time the car has been started and run some time before the failure so it does not happen on a cold start up.
Help!
Monday, March 5th, 2007 AT 4:01 PM
FISHERMAN
  • 937 POSTS
Those intermittent problems are hard to fix.
And always are not there when the mechanic its checking your car.
Could be the "signal" wire that goes from the ignition switch to the starter or the ignition switch itself.
Or a bad male -female connection in betwen the signal wire.
When its not working check for power on the wire that goes to the starter.
Best regards and good luck!
Wednesday, March 7th, 2007 AT 9:56 AM
