1998 Nissan Maxima Hesitation
GETSU
My 1998 Nissan Maxima has 95000 miles and a 3.0 liter (6 cylinder) engine. It is manual transmission. After I shift and let go of the clutch and I accelerate, the car hesitates. The air coming out of the exhaust pipe also seems to choke every few seconds and there is also a slight burning smell sometimes. I have replaced the clutch,shocks,and fuel filter. I have also done all the necessary fluid maintainence. The knock sensor has also been replaced. Nobody seems to know what is causing this problem and the car has passed inspection. Any insight would be much appreciated!
Oct 19, 2007 at 5:26 PM
  • 75,988 POSTS
Check the fuel pressure at idle and part throttle with and without the pressure regulator.
Check these sensors-Throttle Position/Intake Air Temperature/Mass AirFlow.
Also might want to check out the exhaust system for restriction.
Oct 19, 2007 at 5:41 PM
GETSU
Are these serious problems that need to be looked at right away?
Also do u know how much it costs to have these things fixed?
Oct 20, 2007 at 7:17 AM
  • 75,988 POSTS
Are these serious problems that need to be looked at right away? It depends on you those are just probable causes to look at.
My style if it starts up and runs with a lot of gas available I'll drive it till it breaks then fix it That's my mechanic style to lazy to do mine but very fast on customers' car.
Oct 20, 2007 at 9:27 AM
Suggested Repair
Check fuel pressure at idle and part throttle with and without the pressure regulator. Test the throttle position, intake air temperature, and mass airflow sensors, and inspect the exhaust system for restriction.
Conversation Summary
The owner of a 1998 Nissan Maxima with a 3.0L manual transmission reports hesitation after releasing the clutch and accelerating, intermittent exhaust choking, and an occasional burning smell. The clutch, shocks, fuel filter, and knock sensor have already been replaced, and the car passed inspection. The expert suggested checking fuel pressure, the throttle position, intake air temperature, and mass airflow sensors, and looking for an exhaust restriction, while noting these are probable causes rather than a confirmed diagnosis.
