1997 Nissan Maxima Cranks No Start
WISDOME
hello
the car is a 1997 Nissan maxima. 3.0L
when ignition is turned on there is cranking and will not start.
1-we checked for power and there is power. **Where did you check for power**
2- we checked fuel there is fuel.**Did you see it or smelling it**
3 we checked for sparks there is a weak spark occasionally.**What color is the spark**
4-checked crank sensor, its ok.** How did you check it**
5-sometimes while cranking gives a backfiring sound.
still looking for the problem please advise...**Try checking the timing belt-if it has a distributor remove the cap have someone crank it over-is the rotor turning?**
thanks
Answer the above before we continue.
Happy Easter
Rasmatazism
Apr 6, 2007 at 2:30 PM
WISDOME
the car has EI ignition.
-we checked battery power, power to crank sensor, power to spark plug coil, power to injectors.
-we measured fuel by fuel gage pressue and volume.
-spark is one yellowish only once at beginning of each cranking.
Apr 6, 2007 at 9:57 PM
  • 75,988 POSTS
[quote:398580ef5a="wisdome"]the car has EI ignition.
-spark is one yellowish only once at beginning of each cranking.[/quote:398580ef5a]
Was it running fine but quit suddenly? The most likely causes here would be a failed fuel pump, ignition module or**** broken overhead cam timing belt****
What was the fuel pressure?
Do you know how to check the primary and secondary resistances on the coil. Yellowish-spark can be cause by a weak coil.
Apr 7, 2007 at 10:08 PM
WISDOME
[quote:8be89d907f="rasmataz"][quote:8be89d907f="wisdome"]the car has EI ignition.
-spark is one yellowish only once at beginning of each cranking.[/quote:8be89d907f]
Do you know how to check the primary and secondary resistances on the coil. Yellowish-spark can be cause by a weak coil.[/quote:8be89d907f]
thanks for your input ...good advice. Yes we did check the coils and one was burned out so we replaced it.
Im new and dont knw how the site works. want to vote for you how to do that?
Apr 8, 2007 at 12:45 AM
  • 75,988 POSTS
[quote:6c6d17eecc="wisdome"][quote:6c6d17eecc="rasmataz"][quote:6c6d17eecc="wisdome"]the car has EI ignition.
-spark is one yellowish only once at beginning of each cranking.[/quote:6c6d17eecc]
Do you know how to check the primary and secondary resistances on the coil. Yellowish-spark can be cause by a weak coil.[/quote:6c6d17eecc]
Im new and dont knw how the site works. want to vote for you how to do that?[/quote:6c6d17eecc]
Don't even know myself-I guess you click on the feedback lol!
Apr 8, 2007 at 1:58 AM
Suggested Repair
A burned ignition coil was found and replaced after a weak yellow spark appeared only once at the start of cranking. If the no-start continues, verify fuel pressure and volume, test the ignition module, and check whether the overhead-cam timing belt is broken.
Conversation Summary
A 1997 Nissan Maxima 3.0L with electronic ignition cranks but will not start and sometimes backfires. Power was present at the battery, crank sensor, coil, and injectors, and fuel pressure and volume were checked. Spark was weak and yellowish only once at the beginning of cranking. The expert cited a failed fuel pump, ignition module, broken timing belt, or weak coil. The owner then found one burned coil and replaced it, but did not confirm that the car started.
