Nissan Maxima Won't Start
[quote:ae45ce104c="gerrytammy"]We just changed our transmission and our neutral safety switch the car turned over three times and then quit i was wondering if you could help[/quote:ae45ce104c]
Double check from the igniton switch thru the inhibitor/NSS, starter relay and starter itself to include the battery/starter connnections.
May 9, 2007 at 10:26 AM
[quote:40fbf45b54="rasmataz"][quote:40fbf45b54="gerrytammy"]We just changed our transmission and our neutral safety switch the car turned over three times and then quit i was wondering if you could help[/quote:40fbf45b54]
Double check from the igniton switch thru the inhibitor/NSS, starter relay and starter itself to include the battery/starter connnections.[/quote:40fbf45b54]
we have checked all the wiring and connections we tried to jump start the starter and it turned over but won't keep going :?
May 10, 2007 at 5:43 AM
[quote:aed896d75d="gerrytammy"][quote:aed896d75d="rasmataz"][quote:aed896d75d="gerrytammy"]We just changed our transmission and our neutral safety switch the car turned over three times and then quit i was wondering if you could help[/quote:aed896d75d]
Double check from the igniton switch thru the inhibitor/NSS, starter relay and starter itself to include the battery/starter connnections.[/quote:aed896d75d]
we have checked all the wiring and connections we tried to jump start the starter and it turned over but won't keep going :?[/quote:aed896d75d]
Sounds like the overrunning clutch is failing.
Might work if you drop it and break it open and inspect the commutater and brush before you replace it.
May 10, 2007 at 9:33 AM
Suggested Repair
Check the ignition switch, inhibitor/neutral safety switch, starter relay, starter, and battery and starter connections. The expert suspects a failing starter overrunning clutch; remove the starter and inspect the commutator and brushes before replacing it.
Conversation Summary
After the transmission and neutral safety switch were replaced, a Nissan Maxima cranked three times and then would not start. The owner checked the wiring and connections, and jumping the starter made it turn but not continue. The expert advised checking the ignition switch through the inhibitor/NSS, starter relay, starter, and battery connections, then suspected a failing starter overrunning clutch and recommended inspecting the commutator and brushes before replacement.
