2000 Nissan Maxima Coil Pack Light
WILLIAM M. ZOLLO
I have a 2000 maxima with 122,000 miles. Recently my check engine light came on and when I had it read I was told that my coil pack had a problem. The car has no signs of a problem in terms of function. The check engine light goes on and off at different times but the message is always for the coil pack. The technician said the entire coil pack had to be replaced at a cost of $800. My questions are "What is the function of the coil pack?" and "Is there any value in replacing it before it fails?"
Thank you in advance for your help
Dec 12, 2006 at 4:49 AM
BACKYARDMECHANIC
  • 337 POSTS
The coil pack provides current to the plugs in order for them to fire. The advantage of you changing the coil pack is you won't get stuck when it finally goes bad. The $800 dollars sounds a little high, unless you have multi coils (one coil for each cylinder) and you where changing all of them. I recommend you get a second estimate. Hope this helps Backyardmechinic
Dec 14, 2006 at 6:21 AM
Suggested Repair
The coil pack supplies current so the spark plugs can fire. Replacing it before it fails can avoid being stranded, but $800 may be high unless every cylinder coil is being replaced. Get a second estimate before authorizing the repair.
Conversation Summary
A 2000 Nissan Maxima with 122,000 miles has an intermittent check engine light for a coil pack fault but still runs normally. A shop quoted $800 to replace the entire coil pack. The expert explained that the coil pack powers the spark plugs, said early replacement can prevent a breakdown, and recommended a second estimate because the quote may be high unless all individual coils are being replaced.
