1999 Nissan Maxima STARTING
CAMPWIRE
  • 1999 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 206,000 MILES
CAR WON'T START WHEN WEATHER IS HOT
Friday, June 4th, 2010 AT 10:41 PM
Hot or Cold don't wait for nothing do below when it refuses to start could give a head start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, June 4th, 2010 AT 11:04 PM
