1999 Nissan Maxima Car wont start
HANK85
  • 1999 NISSAN MAXIMA
1999 Nissan Maxima 6 cyl Front Wheel Drive Automatic
I have a 1999 nissan maxima. It cranks over perfect, but will not start! I thaught the fuel pump went out on it. So, I replaced the fuel pump, fuel filter, and fuel lines! It is still doing the same thing. It cranks but will not start! Ive checked the fuel pressure to the fuel injectors and its getting perfect fuel pressure. I aslo checked to see if it getting fire to the spark plug and it is firing perfect! I Also put a new fuel pressure regulator on it and it is still doing the same thing! It has me completely puzzled. If any one has any suggestions, PLEASE LET ME KNOW! I would love to here them!
Tuesday, November 2nd, 2010 AT 6:41 PM
You're getting fuel and spark all you need now is compression-check and verify the valve and ignition timing
Tuesday, November 2nd, 2010 AT 7:32 PM
HANK85
I have all ready done that to! Its all perfect! Also I can squirt gas into the throttle body and it starts and runs perfect until it burn out the gas, then it dies and wont start back unless you squirt more fuel into the throttle body!
Wednesday, November 3rd, 2010 AT 7:37 PM
Check the fuel pressure with a gauge to rule out the fuel filter and fuel pump if okay-check if the injectors are pulsing
Wednesday, November 3rd, 2010 AT 7:46 PM
