1999 Nissan Maxima
ALEXFERNANDEZ17
  • 1999 NISSAN MAXIMA
Electrical problem
1999 Nissan Maxima 6 cyl Two Wheel Drive Automatic
the problem is in the engine but electrical. Theres is not power in the injectors, so the car can't start. There is power in the spark's but is not enough power to the injectors. We intalling use engine. On the car, I change the computer of the car, but still not starting. What else I could be looking for.
Monday, March 29th, 2010 AT 11:56 AM
KHLOW2008
  • 41,814 POSTS
Hi alexfernandez17,
Thank you for the donation.
If the injectors are not getting voltage at ignition on, check fuse # 34 ( 20 A ) in fuse box on left side of dash.
Injectors gets power at ignition on and the circuit is grounded by the PCM to fire them.
Did you test the injector wire connectors for battery voltage at ignition ON?
Monday, March 29th, 2010 AT 7:01 PM
