1998 Nissan Maxima floods when trying to start
MAXIWONTSTART
  • 1998 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 18,800 MILES
Ok here's the deal.I have had my car in the shop going on 3 weeks now. The problem is when I go to start it, it wont turn over right away, and it will flood, I have taken it to several mechanics and the CAN NOT figure out what is wrong? PLEASE can some one help me?
Monday, February 22nd, 2010 AT 6:09 PM
SCOTTY DEE
  • 592 POSTS
Hi maxiwontstart! How long is the delay when you go to crank it?
Monday, February 22nd, 2010 AT 6:16 PM
MAXIWONTSTART
  • 10 POSTS
I need to try to start it like 2-10 times before it will finally start up, but sometimes she just floods out:(
Monday, February 22nd, 2010 AT 6:43 PM
SCOTTY DEE
  • 592 POSTS
Are there any trouble codes present?
Monday, February 22nd, 2010 AT 6:45 PM
MAXIWONTSTART
  • 10 POSTS
Not anymore, they changed the oxygen sensor cause that was the code it was giving, now they think its the fuel regulator sensor?
Monday, February 22nd, 2010 AT 6:47 PM
SCOTTY DEE
  • 592 POSTS
I'll guarntee you the O2 sensor was good. The flooding problem will be detected by the upstream O2 sensor, and that would set the code. There has to be 3 things to start an engine, spark, fuel, and compresssion. Has anyone started by looking at engine mechanical?
Monday, February 22nd, 2010 AT 6:56 PM
MAXIWONTSTART
  • 10 POSTS
Ok engine is really good condition. Also the transmission is new. These so called mechanics have checked EVERYTHING so they say. But since they are not able to find out what is wrong with it I am getting REALLY FRUSTRATED! It hasbeen to 2 different mechanics who say they have checked every option. HELP!
Monday, February 22nd, 2010 AT 7:11 PM
SCOTTY DEE
  • 592 POSTS
Don't get frustrated. Cars can be very difficult to work on at times, but they can all be fixed with patience, perseverence, and a diagnostic approach. If it's not firing, we can conclude that the spark is either insufficient, or a communication problem with the powertrain control module.
If they say they have checked everything, and still can't figure it out, it's time to try another shop, and not the cheapest one in town. How much money have you got invested in the last two shops?
Monday, February 22nd, 2010 AT 7:39 PM
MAXIWONTSTART
  • 10 POSTS
Luckily only towing charges, they say if they cant find the problem they wont charge me, so I've been lucky. Would you suggest I take it to a master mechanic?
Monday, February 22nd, 2010 AT 8:16 PM
SCOTTY DEE
  • 592 POSTS
Absolutely. Let me know if you need more assistance/advice.
Tuesday, February 23rd, 2010 AT 8:05 AM
MAXIWONTSTART
  • 10 POSTS
LET ME ASK YOU THIS. YOU THINK JUST A FUSE MIGHT BE OUT? OR DO YOU THINK IT'S ALOT MORE SERIOUS, SEE THIS PROBLEM ALL REALLY STARTED AFTER I HAD THE TRANSMISSION REPLACED, AND HAVE HAD THE FLYWHEEL HAS BEEN CHECKED OUT AND THATS NOT THE PROBLEM. THANKS!
Tuesday, February 23rd, 2010 AT 9:01 AM
SCOTTY DEE
  • 592 POSTS
I doubt it. There is a possibility this could be a whodunnit since the problem began with the transmission replacement. I would want to have the shop recheck their work and make sure this problem wasn't human induced.
Tuesday, February 23rd, 2010 AT 9:35 AM
MAXIWONTSTART
  • 10 POSTS
Are you saying I should take it back to the Transmission shop? But that was like a year ago?And We tried to tell them that they caused it and they simply denied it. What do I do?
Tuesday, February 23rd, 2010 AT 9:38 AM
SCOTTY DEE
  • 592 POSTS
Wow, you've been putting up with this for a year? I would suggest to go ahead and find a good shop and agree to start with an hour of diagnosis time and see where that gets you. You may need to buy more time if they feel they are getting somewhere with a resolution to the problem.
You must ask lots of questions, have a good dialouge with the shop, and never let a stinking cat lay on the porch too long before you get it resolved.
Take the technician for a ride with you, reproducing the symptoms you described for the technician. Got to have everyone on the same page.
Tuesday, February 23rd, 2010 AT 9:44 AM
MAXIWONTSTART
  • 10 POSTS
The whole thing is with the start up, it has nothing to do with the way the car runs.I would've figured that they would've been able to figure it out quicker since it is when the car tries to start up. But thanks!
Tuesday, February 23rd, 2010 AT 12:52 PM
  • 31,937 POSTS
Hi guys,
I have just been reading these posts and if I may I will add my 2 bob's worth, ok. As I see it the problem is hard to start tending to flood but when up and running is ok. So this is what I would be doing, start with cleaning or fitting new spark plugs, checking gaps are ok, or if iridiums fitted don't touch gaps, hook up fuel pressure gauge and key to start (don't crank) check rail pressure, is this ok? Have engine on an oscilloscope or a good quality scanner with ignition snap shot capability and attempt start check ignition KVa readings, my thoughts are that you are down on ignition voltage, you can also get an on car injection test done this will pick up leaking injectors, you can also get the exhaust gasses checked on a 5 gas analyzer, if the Hc's are up you may have an injector leaking, just a few thoughts to help you along a bit.
Mark (mhpautos)
Tuesday, February 23rd, 2010 AT 9:57 PM
MAXIWONTSTART
  • 10 POSTS
Well thank you so much for your two bob's worth, it makes sense. Check this out what the mechanic did to me today, (now keep in mind, my car has been at his shop for 1 1/2 weeks) he says, well if you give me $500.00 I will figure out what the problem is and have it fixed by friday. BUT he's been telling me all week he cant seem to figure out what is wrong with the car.I chunked his dumb ass $50.00 and told him to go find him another DUMBASS, cause I look at it like this. My car has been in his shop for a week and a half and he was supposed to be finding the problem, then he wants to say give me $500.00 and I will find the problem by friday.I was FURIOUS! I think he thought I was gonna be like oh ok do what u need to do. NOT!
Tuesday, February 23rd, 2010 AT 10:09 PM
  • 31,937 POSTS
G'Day,
well some operators are only after you hard earned $$$ and stuff the rest, with the information now at your disposal and a few tests that can be done quite easily, have a talk to a few work shops and see how you get on, I will keep watching.
Mark in Australia.
Tuesday, February 23rd, 2010 AT 10:33 PM
