1998 Nissan Maxima brakes
1998 NISSAN MAXIMA
HEBREW HAMMER
1998 Nissan Maxima 6 cyl Front Wheel Drive Automatic
I just changed my brake pads on my front and back. I had no problem with the fronts but the back ones gave me trouble. I couldn't get the pistons to go in even after renting the right tool. I bought two new calipers to replace the old ones that weren't cooperating. I put them on and bled the breaks. I've only gone up and down my drive way and the pedal still goes down further than it should and the breaks are working on and off, the e brake is working right though. Do I just need to keep bleeding the breaks?
Dec 29, 2008 at 6:23 AM
  • 31,937 POSTS
Hi there,
re bleed the brake and make sure that the fluid level dose not get to low as you may get air trapped in the master cyl, i would start at the master again and do all the wheels just to make sure.
Mark (mhpautos)
Dec 29, 2008 at 9:35 AM
