[quote:edbc4382d8="jam315"]Hello!
so what would would cause the initial "random" locking of the brakes? It would seem that it would be unlikely for both calipers to go at same time right?[/quote:edbc4382d8]
Well, sometimes driving downhill braking to much, the brake pads got crystallized that creates "heat" and that heat it`s transfered to the calipers burning the "piston seals"..
sometimes the master cylinder got "clog "dirty or contaminated brake fluid) and the fluid wont return to the reservoir...
Or could be the case of a distributor valve clog up or failure...
on your case my advice its to check the master cylinder and replace if faulty, check the dist. valve.. (follow the brake lines) cut the rotors, replace calipers and pads and purge the lines one by one...
Also check the back brakes
sounds expensive but could be worse if you have an accident because of that..
Good luck!
Oct 23, 2007 at 4:33 AM
