REMOVAL:
Disconnect the negative battery cable from the battery.
On the VE30DE and VQ30DE engines, remove the air duct.
Disconnect the starter wiring at the starter, taking note of the positions for correct installation.
On the VE30DE engine, remove the connector brackets.
Remove the starter-to-engine bolts ,and remove the starter from the vehicle.
INSTALLATION:
Holding the starter in position, insert and tighten the attaching bolts. Be careful not overtorque the mounting bolts as this will crack the nose of the starter case.
Install the starter wiring in the correct location.
On the VE30DE engine, install the air duct and the connector brackets.
Connect the negative battery cable.
Start the engine a few times to make sure of proper operation.
Thanks for using 2CarPros.com!
SPONSORED LINKS
Tuesday, April 7th, 2009 AT 1:24 PM
