HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Maxima
Fuel System
Fuel Pump
Replace/Remove
1995 Nissan Maxima FUEL PUMP
NJOROABRAM
MEMBER
1995 NISSAN MAXIMA
6 CYL
FWD
AUTOMATIC
180,000 MILES
How do I replace fuel pump on a 95 nissan maxima?
Tuesday, September 9th, 2008 AT 10:14 PM
MECHANIC
If you dont have an access door under the backseat or trunk-you have to drop the fuel tank by removing the tank strap-disconnect the battery and fuel pump connector-remove cover plate and you're there reverse removal procedures-
Wednesday, September 10th, 2008 AT 2:03 AM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Replace/Remove Content
Accelaration Problem
I Have Nissan Maxima 1997 Auto Transmission. It Has A Problem That When I Am Accelerating It Slowly The Pistons Knock And Engine Vibrate....
Asked by
adi1991
2 IMAGES
1997
NISSAN MAXIMA
GUIDE
Fuel Pump Replacement
When a fuel pump goes out it can do so one of two ways either it can quit and stop working or it can fail intermittently causing the engine to stall or not start.
Starts And After About 5 Seconds It Dies?
I Have A 01 Nissan Maxima, If You Push The Gas It Dies Quicker And The Check Engine Light Is Not On. I Replaced The Fuel Pump And Filter...
Asked by
stfej2012
2001
NISSAN MAXIMA
Fuel Pressure Specs
What Is The Fuel Pressure On A 1995 Nissan Maxima Se 3.0 Liter Engine?
Asked by
prisciv627
1995
NISSAN MAXIMA
1990 Nissan Maxima Fuel Pump Will Not Operate
The Fuel Pump Is Not Operating, The Engine Would Start But It Will Not Stay Running Because The Fuel Pump Not Working. I Replaced The Pump...
Asked by
tbutler77
1 ANSWER
1990
NISSAN MAXIMA
Fuel Pressure
What Is The Fuel Pressure Suppose To Read?
Asked by
mdg78745
1 IMAGE
2000
NISSAN MAXIMA
VIEW MORE
Engine Not Starting
How to fix an engine that wont start
Car Cranking but Not Starting? Try This
