Fuel Pressure
With Regulator Vacuum Hose Connected (34 psi)
With Regulator Vacuum Hose Disconnected (43 psi)
Feb 22, 2010 at 4:33 AM
JOE1953
MEMBER
i am about to check the fuel pressure, but can't located the schrader valve.
Dec 13, 2019 at 6:20 PM
(Merged)
✓ASE Certified Mechanic
there is no schrader valve. you need to open the line at the fuel filter and use the correct adapters.
(Merged)
JOE1953
MEMBER
Thanks For Answer my Questions.
(Merged)
you still have issues??
did you do a compression test???
i see you have no noid, but is there 12 volt power to one side of the injector???
have been watching your postings and responses.
(Merged)
JOE1953
MEMBER
do you mean a compression test on the cylinder or fuel pump? i use a noid light on the injector to check for pulse, the light didn't blink, i check for volt there is 12 volt.
(Merged)
compression in all the cylinders.
With no noid, the computer grounds the injectors based on the input from the crank sensor. you did get a response to that and did you replace it??
(Merged)
JOE1953
MEMBER
no i haven't check the compression in all the cylinders neither replace the crank sensor yet.
(Merged)
let us know
(Merged)
JOE1953
MEMBER
there is 12 volt power to one side of the injector but when i check the other side of the injector for pulse my test light do not blink.
(Merged)
you already know this from your previous post. you need to check the crank sensor.
(Merged)
JOE1953
MEMBER
i been trying to located the crank sensor haven't located it yet.
(Merged)
JOE1953
MEMBER
i replace a new crank sensor at the front of the engine under the crankshaft pulley but the engine still want start and there is no pulse at fuel injector connected.
(Merged)
