1991 Nissan Maxima Starting problem
BOWGUY
  • 1991 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 215,000 MILES
We have had this Maxima since new, love it, had the engine rebuilt and a new radiator. The problem we can't seem to solve is an intermittant starting problem. The car can go for months and then all of a sudden, you can stop, go into a building for a few minutes, come out and it won't start. If you try a few times, nothing. If you leave it alone for an hour or two, or perhaps overnight, it starts upimmediately then may not a week or even a few months before it doesn't start again. When it won't start it sounds like a higher pitched starter than on a usual start without "turning over. Any help?
Wednesday, June 11th, 2008 AT 8:34 PM
KHLOW2008
  • 41,814 POSTS
Hi bowguy,
Do you mean there is a whining noise without the starter engaging and cranking the engine?
If yes, then either the starter or flywheel ring gears are worn and would cause this problem intermittently.
Thursday, June 12th, 2008 AT 10:02 AM
