2000 Nissan Frontier Cranks but won't start
CHADJB
  • 2000 NISSAN FRONTIER
  • 4 CYL
  • MANUAL
  • 165,000 MILES
Installed a Dakota Digital CRS 3000 cruise control in my now it won't start engine cranks, I have spark, will run if I put fuel in throttle body. Fuel pump does not run- verified by pulling line off fuel filter and turning truck on. Check fuel pump fuse-not blown, swaped fuel pump relay- nothing. The wires I tyed into are the VSS and Tach wires behind the instrument cluster, hot and cold side of break switch, and the accessory wire(black with white tracer) coming out of the right upper corner of the fuse panel. Can you tell me why my fuel pump won't run.
Saturday, June 26th, 2010 AT 12:45 PM
No fuel no start
Start here power the fuel pump direct from the battery and see if it'll come On.
Saturday, June 26th, 2010 AT 2:11 PM
CHADJB
I check the fuse it has power, I unplugged the fuel pump relay and check the terminals that should have power and they do. I check wires going to fuel pump (pumps in tank) and I have NO Power at the pump. Tried swapping out relay. Still no power. The print shows nothing else in the circuit
Sunday, June 27th, 2010 AT 5:58 PM
