2000 Nissan Frontier crank won't start
FRAJAGAMO
  • 2000 NISSAN FRONTIER
Noises problem
2000 Nissan Frontier 4 cyl Two Wheel Drive Automatic
i drive this truck for 2 days listening noise on the engine (top) after 2 days tried to start, crank but won't start and go the noise thanks.
Wednesday, February 17th, 2010 AT 8:18 PM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Wednesday, February 17th, 2010 AT 8:23 PM
