Odometer reads "999999"
1998 NISSAN FRONTIER
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
CINCY22AMOS
I'm having trouble figuring out what went wrong with my Frontier! A couple days ago my odometer, gas gauge, and oil gauge just went nuts. The odometer reads "999999" and all my gauges are out of whack! I've already checked all fuses, but no luck. The thing that throws me off is that I disconnected the harness to the ignition switch, then reconnected it, then BOOM - it worked . . . For a couple of minutes. I'm lost! Please, any suggestions??
Dec 6, 2007 at 5:58 AM
MRWHIZARD
  • 7 POSTS
Common problem with this vehicle. The memory/configuration chip is corrupted.
Jan 3, 2008 at 11:12 PM
JEEP99899
I am having the same issue with my 98 Nissan Pathfinder.
Jan 8, 2008 at 11:56 AM
MRWHIZARD
  • 7 POSTS
Does the pathfinders odometer read all 9's. What do the gauges do?
Jan 9, 2008 at 7:49 AM
JEEP99899
The temp gauge and gas gauge max out. The odometer reads 9999999, the speedo will not go over 20 MPH and the tack jumps. Does not happen all the time, some days it works normal all day long. Other days it goes nuts all day long. Most of the time it is 1/2 good, 1/2 freaky.
Jan 9, 2008 at 11:58 AM
MRWHIZARD
  • 7 POSTS
Happens in Pathfinders too as well as 98-99 Frontiers. I had to get a rebuilt cluster cost me $154.00 all fixed!
Oct 17, 2008 at 2:23 AM
