Battery gauge
56,000 MILES
NGB5548
  • 32 POSTS
Is it normal for the battery gauge to fluctuate slightly when driving? I've noticed it goes to 12v when you turn accessories on, then when you start the engine and drive it will fluctuate between 14 and 15 (roughly). I just had my electrical system checked and they said it was good, but I just noticed this today.
Mar 4, 2016 at 12:57 PM
  • 31,937 POSTS
It should stay fairly steady, it may drop as you use things like heater and high beam or heater blower, but basically it should stay steady. You may have a voltage regulator starting to fail. I would check the drive belt, don't ignore this as it will let you down when you really need it.
Mar 4, 2016 at 2:45 PM
NGB5548
  • 32 POSTS
Thanks. It remains steady for the most part, and changes only slightly sometimes during driving or when I use something in the car. I passed the electrical test and they said everything looked good. This may be something I just now started noticing and has always been this way. I'll keep an eye out for it. Thanks for the help!
Mar 4, 2016 at 10:38 PM
  • 31,937 POSTS
Your welcome please repost if you have any further concerns.
Mar 5, 2016 at 6:06 AM
