1995 Nissan Altima Oil Leak at Distributor
JEEFUNK
I have a 1995 Nissan Altima, roughly 140k miles. Recently, I've discovered an oil leak that has apparently been there for a while. Here is a picture: (if anyone would like a full-size pic, I can provide that)
[img:752c9a44b6]http://www.2carpros.com/forum/automotive_pictures/54499_11707_distributor_pics_002_1.jpg[/img:752c9a44b6]
There is a lot of oil residue (see pic), so I'm not 100% sure of where the leak is coming from, but I would say it is more than likley coming from the distributor. After speaking with a local mechanic, he said that all I would need to do is take the distributor cap off & spray with brake/carburetor cleaner and that would take care of it. Can anyone confirm/explain this better?
Jan 18, 2007 at 1:28 AM
  • 75,988 POSTS
Double check the valve cover gasket-if its not it- 99.9 its the distributor shaft O-ring-need to remove distributor for replacement. HTH-Good LUck!
Jan 18, 2007 at 7:36 PM
Suggested Repair
Check the valve cover gasket first. If it is not leaking, replace the distributor shaft O-ring, which requires removing the distributor. Cleaning the cap with brake or carburetor cleaner will not stop the leak.
Conversation Summary
The owner of a 1995 Nissan Altima with about 140,000 miles reports an oil leak and residue around the distributor. A local mechanic suggested removing the distributor cap and spraying it with brake or carburetor cleaner. The expert says to check the valve cover gasket first; if that is not the source, the distributor shaft O-ring is almost certainly leaking and the distributor must be removed to replace it.
