1997 Nissan Altima Oil Leak
NATALIED
I have a 4 cylinder 97 Nissan Altima that has 182,000 miles on it.
The other day, I noticed a little oil on the pavement. I turned the car on today, and the engine sounded really rough. I checked the dip stick and there was virtually no oil in the car. I drove it last night, and I didn't notice the sound. I know that I put 2 quarts in about a month ago. This is the first time that I have seen any oil leaks.
Have I caused any serious damage?
My hubby is deployed in Iraq, so I am left by myself to take care of not only the car but the kids too. I also noticed that the oil was very dark --I know that means I need an oil change. I would appreciate any help you could give me
Jan 26, 2007 at 4:58 AM
MATHIASO
  • 1,209 POSTS
you have a major oil leak. do not drive your car without oil,driving without oil will definitely damage the whole engine.
Please, take your car to a mechanic to take care of the problem.
oil change won't help until you repair the leak by a mechanic.
Jan 26, 2007 at 4:26 PM
Suggested Repair
Do not drive the car with little or no oil. Have a mechanic find and repair the major oil leak before changing the oil.
Conversation Summary
The owner of a 1997 Nissan Altima with 182,000 miles found oil on the pavement, a very low oil level, dark oil, and a rough-running engine after recently adding two quarts. The expert said this is a major oil leak, warned that driving without oil can damage the engine, and advised taking the car to a mechanic. An oil change alone will not help until the leak is repaired.
