1996 Nissan Altima Won't Start
ISAACSAL
Nissan Altima 4cyl
1996, 140,000 miles
Automatic Trans
I have a Nissan Altima that will not start. I tried to jump it but nothing happens. The battery seems to have power but not sure why it won't turn over. I hear a clicking noise when the key is turned. But the engine does not turn over.
Oct 21, 2007 at 10:34 AM
FAIRRACING31
  • 150 POSTS
The clicking you hear is your starter solonoid. The solonoid tells your starter to engage and start your motor. There are two things that will cause this. 1. Your starter is bad and need to be replaced. 2. It is not getting the correct voltage. Check your battery for voltage 11.5-12 volts, be sure your battery terminals are clean and making good contact, also check your battery cables.
Oct 21, 2007 at 10:58 AM
Suggested Repair
Check battery voltage (about 11.5-12 volts), clean the battery terminals, and confirm the cables make good contact. If voltage and connections are good, replace the starter, since the click indicates the starter solenoid.
Conversation Summary
The owner of a 1996 Nissan Altima says it will not start or turn over after a jump attempt. A clicking noise occurs when the key is turned, although the battery appears to have power. The expert identifies the click as the starter solenoid and recommends checking battery voltage, terminal contact, and battery cables, or replacing a bad starter.
