1995 Nissan Altima Hard Cold Start
DADFAD
1995 Nissan Altima - "When cold or having sat for awhile... engine will turn over but not start. If you push
accelerator to floor then pump it while engaging starter you can usually get to start and blows black
smoke like flooded then clears up after repeated engine acceleration"
May 3, 2007 at 1:37 AM
  • 75,988 POSTS
[quote:16e6194daa="dadfad"]1995 Nissan Altima - "When cold or having sat for awhile... engine will turn over but not start. If you push
smoke like flooded then clears up after repeated engine acceleration"[/quote:16e6194daa]
Sounds like the coolant temperature sensor, check the connection-test its resistances cold and hot. It will do this-try this 1st.
Could be also a fuel pressure problem-check pressure regulator/pump
HTH Good Luck
May 3, 2007 at 8:06 PM
Suggested Repair
Check the coolant temperature sensor connection and test its resistance cold and hot. Also check fuel pressure, including the pressure regulator and fuel pump.
Conversation Summary
A 1995 Nissan Altima cranks but will not start when cold or after sitting. Flooring and pumping the accelerator while cranking usually starts it, followed by black smoke that clears after repeated acceleration. The expert suggested checking the coolant temperature sensor first, then fuel pressure, the regulator, and the pump.
