Atlima 97 Distributor
1997 NISSAN 300ZX
JANNAYF
My car had hard time starting and then it died on me on the road.
The mechanic tells me that I need a new Distributor and a tune up after that.
He claims the dist. is around 300 (checked in Autozone = 200).
Is it true that I need a tune-up also after I install the dist. or are they making false claims. After all I could just attach the distributor on my self.
Thanks
Feb 6, 2007 at 6:46 AM
[quote:a48b0554d7="Jannayf"]Hi,
Thanks[/quote:a48b0554d7]
Do you have any OBD2 codes-If you don't know anything about valve and ignition timing don't. Deal with the Pros.
FYI Nissan's distributors anything wrong inside calls for replacement-check the ignition fuse if it has one.
Feb 6, 2007 at 7:51 PM
LANA
[quote:027c9922ef="Jannayf"]Hi,
i dont think you need a distributor make sure you dont have any code on system. is your car running very bad is the idle going up down?you should look forward to bring your car to a dealership if you dont have a scaner,
Thanks[/quote:027c9922ef]
Feb 10, 2007 at 6:38 AM
SWORN2PRTCUSA2002
  • 5 POSTS
It is very possible that it is your distributor. They are very easy to replace. Just make sure you put the #1 piston at TDC(top dead center), line up the timing marks before you remove it and you are good to go. I replaced mine in about 45 minutes on my 95 Nissaan Altima GXE. I had the same problem. The car would die on the road and I waited about an hr or so and it started back up. It could also be a manifold absolute pressure sensor. But take the advise of the prior. ask the pros if your are unsure how to mess with these things. I am just an exprimenting mechanic. (shade tree) although I have had success dong my own work. Never had to use the pros. Just mechanically inclined I guess. Good luck.
Feb 19, 2007 at 3:41 AM
