1990 Nissan 300ZX no spark
CHEVYMAN1988
Electrical problem
1990 Nissan 300ZX 6 cyl Two Wheel Drive Manual
i just did an engine swap in my 300 zx and when i went to start it the engine cranks but i am getting no spark, what could be some things i can double check?? both engines ran when they were pulled
Apr 18, 2009 at 11:03 AM
  • 75,988 POSTS
If all connections are okay-
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard
Apr 18, 2009 at 11:07 AM
