1997 Nissan Altima Leaking Strut
SCIVET
Lately, I bought a used car, Nissan Altima 97 (92k mi.). I was told from the mechanic that the left/front strut has a leak and it needed changing. Now I can't afford it so, I asked him when it's a good time to replace it. He answerd, it's up to me, and I also asked him what if i don't change it? He said it wouldn't cause any problem, because the mileage is not too much.
So what i want to ask is, if i don't change the strut for the next several years, will it cause any problem to the other mechanical parts of my car?
Now I can't feel any problem when i drive it.
Dec 21, 2006 at 11:01 AM
BOOTDOG
  • 665 POSTS
the only thing a leaking strut can cause is if it's weak it can make the tires wear unevenly ie, cupping. the other problem is that certain states have state inspections and i know here in the state of virginia, a leaking strut or shock will not pass inspection. i would look into this if your state has inspections.
Dec 21, 2006 at 1:31 PM
Suggested Repair
Replace the leaking left front strut when possible. A weak strut can cause uneven tire wear such as cupping, and a leaking strut or shock may fail inspection in some states, so check local inspection rules.
Conversation Summary
The owner of a 1997 Nissan Altima with about 92,000 miles was told the left front strut is leaking but feels no driving problem and asked whether delaying replacement for years would damage other parts. The expert said a weak leaking strut can cause uneven tire wear, including cupping, and may fail state inspection where inspections are required.
