Nissan Altima Soft Brake Pedal
BOOYAU
200 Nissan Altima SE, 91000+, 4cyln: When I step on the brakes I need to apply more than the normal amount of pressure. I just changed my brake pads, brake discs and one of the calipers. Do I need to change\add in brake fluid or is there something else going on with the car?
Thanks,
Jul 9, 2007 at 6:47 AM
LOU P
  • 118 POSTS
anytime the brake hydraulic fluid is lost like when you replace a caliper, you need to flush the system to bleed the air out of the system . if not your pedal will feel soft and spongy and it will take more force to apply the brakes to stop the car.
Apr 7, 2016 at 12:30 PM
Suggested Repair
Bleed and flush the brake hydraulic system to remove air introduced when fluid was lost during caliper replacement.
Conversation Summary
The owner of a Nissan Altima replaced the brake pads, discs, and one caliper, then needed more than normal pedal pressure. The expert explained that lost fluid during caliper replacement lets air into the system, so the brakes must be flushed and bled or the pedal will feel soft and require extra force.
