1997 Nissan Altima Brake Pads Sticking
DJ_KWICKY
I have a 1997.5 Nissan Altima Limited Edition. I have just replaced the front brake pads on both sides of the car. When I depress the brakes the brake pads stick to rotor on the drivers side. I took them off and cleened and greesed up the pins and it still is sticking. I have noticed that the brake pads don't snap in snugly. They sit very loose in the brake pad housing clips. Just need to know how to make this stop so I don't keep wasting rotors and brake pads. Thanks, djkwicky
Mar 18, 2007 at 2:13 PM
PEPPERMRJ
  • 1,158 POSTS
I would mount the caliper with out the pads and using my hand make sure it slides freely back and forth.
If it does this freely I would suspect a collapsing brake hose or the caliper pistons are not releasing. Jack the car up.
Put it on jack stands.
Apply the brakes.
Try and spin the wheels by hand to see if the brakes release.
If not crack the bleeder valve open for a split second to release the pressure. If the wheel now spins the hose is bad or there is some other restriction in the brake lines that is holding pressure.
If the wheel does not spin the calipers should be either rebuilt or replaced.
**************Do this in pairs.**************
Good luck and let us know. :)
Mar 18, 2007 at 4:07 PM
Suggested Repair
Confirm the caliper slides freely without pads. If it does, jack the car securely, apply the brakes, and check whether the wheel releases. Briefly cracking the bleeder can show whether a collapsing hose or line restriction is holding pressure; if the wheel still will not turn, rebuild or replace the calipers in pairs.
Conversation Summary
The owner of a 1997.5 Nissan Altima replaced both front brake pads, but the driver-side pads stick to the rotor and fit loosely in the clips. Cleaning and greasing the pins did not help. The expert advised checking free caliper movement, then testing whether the brakes release after application. If opening the bleeder frees the wheel, a bad hose or line restriction is likely; otherwise the calipers should be rebuilt or replaced in pairs.
