1998 Nissan Altima Spark Plugs
PRASANNABANWAT
  • 1998 NISSAN ALTIMA
Engine Mechanical problem
1998 Nissan Altima 4 cyl Automatic 128000 miles
How hard it is to change the sparkplugs on the 1998 Nissan Altima GXE?
Could you provide step by step procedure or video for the said?
Thursday, September 2nd, 2010 AT 7:41 AM
MADMIKE1735
  • 951 POSTS
On the very top of your engine you will see 4 black plugs with wires on them. Those are your spark plug wires. Those go to your distributor cap. Do a full tune up. Plugs, wires, cap, rotor. Very easy job. I suggest while your buying parts, you buy the book on your vehicle as it will give indepth info and pics. If u want to save that 20$ then I suggest you buy a paint stick, and mark your wires from where they come out of the valve cover, and where they go to the distributor cap. Assuming that u have stock wires on it now, they should be marked 1, 2, 3, 4. Also, buy the plugs that the manufacturer recommends, and dont skimp out on money. This is a very important part of your engine.
Thursday, September 2nd, 2010 AT 10:05 PM
PRASANNABANWAT
Thanks! It worked out fine!
Monday, September 13th, 2010 AT 4:34 AM
