HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Altima
Ignition
Spark Plug
Replace/Remove
2004 Nissan Altima no power
RAFO
MEMBER
2004 NISSAN ALTIMA
6 CYL
2WD
AUTOMATIC
145,000 MILES
No power at wide throttle replaced spark plugs
air filter re program idle speed and timming to spec.
top speed 50mph. No codes present can you help.
Wednesday, May 21st, 2008 AT 10:00 PM
MECHANIC
Inspect and test these sensors-throttle position/vehicle speed/mass airflow sensors-to include fuel pressure check.
Wednesday, May 21st, 2008 AT 10:14 PM
RAFO
MEMBER
I'll check thanks
Thursday, May 22nd, 2008 AT 5:19 PM
Please
login
or
register
to post a reply.
Related Spark Plug Replace/Remove Content
2004 Nissan Altima
I Am Attempting To Remove And Change The Spark Plugs With The Hynes Repair Manual Here. I Read The Page On Removing And Changing However...
Asked by
humble_origin
1 ANSWER
2004
NISSAN ALTIMA
VIDEO
Spark Plug Gap
Instructional repair video
GUIDE
Spark Plug Replacement
A spark plug is a vital part of the engine's ignition system and is responsible for starting the combustion process. As a part of an engine tune up, spark plugs should ...
The Spark Plugs First In Cylinder 2 Then In 1 Appeared...
And/or Overheated, This Happens After Engine Reaches Operating Temp. The Car Started Running Rough And Stalling The Other Day. When I...
Asked by
tpboy
2004
NISSAN ALTIMA
No Spark On Third Cylinder After Replacing The Coil...
Hi, Recently I Had To Replace The Coil And Spark Plug On The Third Cylinder But Now I Am Not Getting Any Spark Its Getting Fuel And...
Asked by
mattsr
2005
NISSAN ALTIMA
2002 Nissan Altima Fouled Spark Plug
Recently I Had A Problem With One Of My Catalytic Converters It Shattered Into Pieces. So, I Replaced It With New Headers, That Only Had...
Asked by
bgrich2003
2002
NISSAN ALTIMA
Nissan 2003 2.5s, Started Shaking. Sometimes When I...
Nissan Altima 2.5s 4cyl. I Was Driving Fine, Tuned Off The Car To Go Into A Store, When I Turn It Back On I Began To Shake And As I Was...
Asked by
parisbrooke
2003
NISSAN ALTIMA
VIEW MORE
Change the Spark Plugs 6.0L V8
Spark Plug Replacement - Chevrolet
Spark Plug Change Hyundai
