NO spark on third cylinder after replacing the coil and spark plug
180 MILES • 2.5L • 4 CYL • 2WD • MANUAL
MATTSR
Hi, recently i had to replace the coil and spark plug on the third cylinder but now i am not getting any spark its getting fuel and compression just no fire. i started the car and removed the connectors on one, two and four which reduced the rpm's right away. when i removed the plug on the third cylinder there was no change, but the plug was drenched with fuel. i do not know what to look for next except the connector itself maybe shorted out.
Sep 19, 2016 at 8:45 PM
HMAC300
  • 48,601 POSTS
with misfires it is best to have a mechanic do these as you can end up dumping a lot of money and still have problem . he can scan for codes. If you like check for a vacuum leak and check compression on the offending cylinder.
Feb 24, 2017 at 7:52 AM
  • 55,743 POSTS
Hello, if I may butt in here,
You could have an ignition coil driver inside the computer that has failed, check for coil pulse to confirm here is a guide that can help you.
Please let us know what you find so it will help others.
Best, Ken
