The ka24de engine's oil pan is easily accessible and relatively small compared to others because it is two pieces. The upper connection to the block usually doesn't leak, most of the time it is the small pan on the bottom in which the oil drain plug is installed. Be careful not to over tighten the bolts because they will break off
SPONSORED LINKS
Tuesday, September 30th, 2008 AT 10:20 PM
