1995 Nissan Altima GAS-N-OIL
SHORTY17
  • 1995 NISSAN ALTIMA
  • 4 CYL
  • 206,413 MILES
The car was hard to start, and when it did it smoked white smoke, A lot. Drove 2 blocks staled out engen. Now it won't start.
Wednesday, March 24th, 2010 AT 12:49 PM
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Wednesday, March 24th, 2010 AT 2:32 PM
