i have a 1989 nissan 240sx and the fuel gauge does not work the needle is all the way down its nt even on the E wat could be wrong with it
Oct 16, 2007 at 2:28 PM
FISHERMAN
✓Experienced Mechanic
[quote:22b76ffece="medinafx"]i have a 1989 nissan 240sx and the fuel gauge does not work the needle is all the way down its nt even on the E wat could be wrong with it[/quote:22b76ffece]
Hello !!
Well start checking the back of the dashboard for a loose connector or wire...
if everything good you have to drop the gas tank and check the Potentiometer (gas level sender unit) or connector.
