I am at my wits end trying to figure this one out. If I turn the key to the start/crank position, it will not turn over. I have checked all the fuses in the both the engine compartment and the passenger compartment. It is a standard transmission. I have tried bypassing the clutch switch and that didn't help. If I turn the key to the crank position I can hear several relays clicking when I go from the crank position back to the run position. I also tried switching the relays around and that didn't help. If I turn the key to the run position and then run a positive wire to the starter solenoid, it will crank over and start without a problem. I don't see any obvious wiring problems.
Oct 11, 2007 at 2:37 PM
